Activity › Forums › Apple Final Cut Pro Legacy › Deck control of JVC SR-VS30U FCP
Posted by Douglas on May 16, 2006 at 6:31 pmHello –
I just added a JVC DV/SVHS deck to my FCP (studio 5)system. I get a menu that FCP failed to initialize the deck when I try to capture. In addition to getting a ‘no communication’ message, I also can’t capture anything. I get a screen of black and it says I’m capturing, but when I end the capture there is no clip. And I just assumed I would have deck control through FCP – is this possible with the SR 30? Any guesses as to what step I’m missing?
Douglas replied 20 years, 4 months ago 3 Members · 4 Replies -
Kevin Monahan
May 16, 2006 at 8:01 pmIs the deck on the list of approved devices?
Kevin Monahan
Take My FCP Master’s Workshop!
fcpworld.com -
Douglas
May 16, 2006 at 8:27 pmWell, not sure about that. I’ve heard lots of people are using this deck with their nle’s so there must be a way to capture footage.
Rob Forsythe
May 16, 2006 at 10:34 pmFist, make sure the FW connection is working by connecting the JVC unit directly to a camcorder via FW and see if you can get an image from the JVC to show up on the camcorder (camcorder in “VCR” mode) while playing a DV tape in the JVC.
THEN:
This list contains virtually everything to try to enable:
a. External Monitor VIDEO and AUDIO via FireWire & DV deck or camcorder.
b. Viewing in the Canvas window on the computer screen.
c. Being able to record on the external FW DV deck or camcorder.
d. Being able to capture from a FW device.If working this list doesn’t cure the problem… you may have a serious PROBLEM!
Try things in this order until you find the “cure”:
1. Make sure you have only ONE (1) FireWire deck, camcorder, DV capture “card”, or D-to-A converter or video device attached to the computer at a time. Any more than one DV device can cause loss of signal and control.
2. Make sure you have View (Menu) > External Video> All Frames set.
(If the ALL FRAMES option is grayed-out… jump to step 6 below and continue.)
3. Make SURE your Canvas window (right window) in FCP is set to “Fit to Window”… AND that it has not been “pushed off” the edge of the computer screen.
4. Make sure your CANVAS View Menu (Box Icon with broken sides) is checked on Image or Image+Wireframe… NOT just Wireframe.
5. Make sure your CANVAS View Menu is checked on RGB… NOT just Alpha.
6. Make sure your Final Cut Pro (menu) > Easy Setup… is set for DV-NTSC (or DV-PAL, if that’s where you are).
7. Some camcorders/decks work better under “FW (NTSC/PAL)” -or- “FW (NTSC/PAL) Basic” control (in the capture settings). Try either setting to see which works best for your device.
8. Make sure your Final Cut Pro (menu) > Audio/Video Settings > A/V Devices (tab) > Mirror on Desktop > must be CHECKED. (If not, playing video will not appear in the Canvas.)
9. Make sure the “Log and Capture” Window is CLOSED and not just “hidden” behind other windows.
10. Make sure you have chosen FW output for A/V:
Final Cut Pro (menu) > Audio/Video Settings… >
Video Playback: Apple FireWire NTSC (720 x480)
Audio Playback: FireWire DV
11. Turn off the power to the Camera/Deck/Converter Box, then turn it back ON.
12. Make sure the camera is in VTR mode… or the deck is in DV (DV, iLink, or FW) input.
13. On a Sony camcorder or deck, make sure the menu setting “A/V > DV Out” is set to OFF.
14. Re-check that your FW cable is well-connected at both ends (or try a new cable).
15. Important: Quit FCP, then Restart FCP.
16. Now again, make sure you have View > External Video > ALL FRAMES set…If it still does not work. “Trash” the FCP Preferences on the Mac
“FCP Rescue” is a free Apple Script that will Trash the Preferences.
It will also restore your user settings afterwards.
Download:
https://www.macupdate.com/info.php/id/14729If you have “lost” your entire FW connection between the Mac and the device, go HERE:
https://docs.info.apple.com/article.html?artnum=301852>Then, start again at my “step 1” above.
Douglas
May 17, 2006 at 5:18 pmThanks for taking the time with such a thorough response Rob. I’m thinking more and more it’s a deck problem.
Doug
