Activity › Forums › Adobe Premiere Pro › Dealing with multiple output formats and screen size
  • Dealing with multiple output formats and screen size
    Posted by Matt Lemsing on March 7, 2012 at 12:48 pm
    Hi there.
    Im about to start editing a short film that ultimately will be need to be shown on 1080p screens, Vimeo, and 576 format projector. I guess my question is what sequence settings should I use in premiere pro CS5? Is there a best way to setup the footage and project knowing that I’m going to exporting to different size screens?
    Any advice or thoughts appreciated.
    Cheers,
    Matt
    Matt Lemsing replied 14 years, 6 months ago 3 Members · 3 Replies
  • Petros Kolyvas
    March 7, 2012 at 4:20 pm
    I would edit in 1080p and convert as required for your additional deliverables. With 1080p as one of your target specs, there’s no reason to compromise on anything else.
    Watch your safe zones as you would with any edit and you should be alright!
    There is no intuitive interface, not even the nipple. It’s all learned. – Bruce Ediger
  • Alex Udell
    March 7, 2012 at 7:07 pm
    this brings up a good point…
    what’s the easiest way to set up “center cut” overlays in PPro?
    make a title?
    Alex
  • Matt Lemsing
    March 7, 2012 at 8:59 pm
    Thanks Petros.
    So to be clear, I assume that means setup my sequences at 1080p and then when I export I choose whatever scaled format I need correct? And becuase I have started with bigger/higher res and I am only down scaling there will be no loss in qualty etc.
    Please confirm.
    Matt
