Activity › Forums › Adobe After Effects › Deadline on Monday! and I can’t EXPORT!
  • Deadline on Monday! and I can’t EXPORT!
    Posted by Ariel Brener on January 8, 2010 at 8:52 am
    Hello I have a big project:
    Lots of assets – I also used extensive footage from Premiere Pro and used the amazing dynamic link.
    I’m using the Render queue – Lossless preset.
    So I don’t think its a problem with conversion codecs etc…
    some composiitons\parts of the project I can export – but some I can’t – I think it might have something to do with muti-cores\RAM issues.
    what can I do?
    I need to export it back to premiere to do the Music & effects part.
    I tried sending a comp to Premiere but the Apple will just kept on turning endlessly.
    Help me please!
    ________٩(̾●̮̮̃̾•̃̾)۶________
    New Rig (Leopard 10.5.7):
    Final Cut Studio 3
    CPU: Core i7 920
    RAM: 12gig
    GPU: GTX 285 2GB OC
    HDD: 6 X 1 TB HDDs: 4 HDDs in RAID-5 and 2 HDDs for System.
    David Bogie replied 16 years, 8 months ago 4 Members · 3 Replies
  • Anders Hattne
    January 8, 2010 at 11:22 am
    Do you get any error message, or does it just crash?
    http://www.ardillamedia.com
  • Mark Landman
    January 8, 2010 at 2:04 pm
    I had a similar problem a few weeks ago. The problem turned out to be one of my internal hard drives. If you have TechTool or a similar disk utility, check the SMART status of your drives. In my case one of the drives passed the test, but 3 of the drive parameters were in the yellow-indicating that the drive could fail soon. As soon as I removed that drive from the system the spinning beachball of death disappeared.
    Mark Landman
    PM Productions
    Champaign, IL
  • David Bogie
    January 8, 2010 at 3:52 pm
    The question appears on at least one other AE forum.
    I don’t see enough information in the OP to help you much but my alarms always go off when folks use “export” from AE instead of “render.” When using CS4 with Premiere, the route to and from AE is effectively and efficiently accomplished with links, not new media. Do you have enough experience with CS4 to know how the applications work together?
    bogiesan
