Activity Forums Apple Final Cut Pro Legacy de interlace filter sucks !!!
  • de interlace filter sucks !!!
    Posted by Rajarshi Basu on August 19, 2008 at 9:28 am
    I am editing a feature length documentary and I need to deinterlace my footage. Never had such issues in Premiere or Avid.
    what are the good 3rd party deinterlace filters available for FCP ?
    RAj
    Jeremy Garchow replied 17 years, 11 months ago 15 Members · 50 Replies
  • 50 Replies
  • Andreas Karoliussen
    August 19, 2008 at 12:10 pm
    I like stibs pluggins: https://pureandapplied.com.au/plugins.html
    and
    Mattias pluggins; Tmts: https://www.mattias.nu/plugins/
    or you can try to turn your sequence settings field dominance to none…
    Best regards Andreas
  • Andy Mees
    August 19, 2008 at 12:37 pm
    RE:Vision Effects Fields Kit
    https://www.revisionfx.com/products/fieldskit/
  • Tracey Dunn
    August 19, 2008 at 1:26 pm
    Nattress film effects
  • Jeremy Garchow
    August 19, 2008 at 3:19 pm
    [Andy Mees] “RE:Vision Effects Fields Kit “
    Another vote for this one.
  • David Bogie
    August 19, 2008 at 4:30 pm
    Even more fundamental:
    If you knew you had to deliver frames, why did you shoot fields?
    bogiesan
  • Ed Dooley
    August 19, 2008 at 4:37 pm
    Not to take away from the other suggestions, they are all good, but Compressor using Frame Controls also works well, and you already have it. Do a search, it’s been discussed a bunch of times here.
    Ed
  • Sean Oneil
    August 19, 2008 at 6:30 pm
    Simplest solution of all. Change field dominance to None. This will work in certain scenarios. As Dave mentioned, without knowing what kind of footage your dealing with it’s impossible to say what the best solution is.
    Sean
  • Rajarshi Basu
    August 19, 2008 at 11:15 pm
    Hi dave,
    The footage has been shot in Sony Pd 170 and Z1P in DVCam mode. Its 25fps.
    I will be broadcasting it from Digi Beta. So I will be doing my final color correction on Quantel or Smoke where I will scale up the footage to make the film 16:9 and then transferring it to Digi Beta.
    Previously I have been editing on Avid and Premiere and faced no such problem. Its only in FCP it seems this issue exists.
    Raj
  • Rajarshi Basu
    August 20, 2008 at 6:49 am
    Hi Dave,
    The thing is, this documentary is meant for broadcast on BBC and Arte France. And they have a lot of broadcasting specs.Like they want the final film to be true 16:9…so the upscaling…
    And yes, if its finally shown on digibeta, there will be letterboxing…thats the confusing part for me…
    Firstly I am an editor, I can color correct maybe a short film, but to color correct a 120min video is too much.
    Secondly, scaling the image in an online machine will be less lossy then doing it on FCP..isn’t it ?
    Raj
  • Jason Porthouse
    August 20, 2008 at 10:04 am
    Raj,
    Firstly – yes, the DI filter in FCP aint the best. For you, I’d talk to your graders first – they may have a good DI filter in Smoke or Quantel that will do fine.
    For resizing 4:3 to 16:9 I’d use Digital Anarchy’s ReSizer. You can get some nice results – there’s also a de-interlacer included in that that’s worth trying…
    JP
    _________________________________
    Before you criticise a man, walk a mile in his shoes.
    Then when you do criticise him, you’ll be a mile away. And have his shoes.
    *the artist formally known as Jaymags*
Page 1 of 5
