Activity Forums Media 100 DCVPROHD 1080i to DVD
  • DCVPROHD 1080i to DVD
    Posted by Dave Simpson on September 19, 2012 at 1:03 pm
    Hi All,
    I have a program edited for Broadcast done in DVCPROHD 1080i. I also need to make a DVD for a presentation. How should I export the timeline to burn a DVD in I DVD and maintain as much quality as possible? I know it won’t still be HD but any advice as to how to get the best results would be appreciated.
    I’m using Media 100 Suite 2.0.1 and I have Adobe Media Encoder and Compressor if need be.
    Dave
    Dave Simpson replied 13 years, 7 months ago 2 Members · 2 Replies
  • Bernhard G.
    September 21, 2012 at 7:39 am
    Hello,
    The topic You should be interested here is scaling and file-based
    standards conversion
    DVD-coding itself is not the problem, since You could
    get the very best coder in the industry for an affordable price:
    https://www.cinemacraft.com/en/ccemp.html
    Scaling frequently comes up in the forums; the bad answer:
    There is not a single good software standards converter out there.
    Well, there is Amberfin, but their’s iCR standards converter costs $$.$$$.-
    https://www.amberfin.com/products/icr-standards-converter
    It offers the very best scaling because it’s based upon the Snell&Wilcox HW converters…
    But for the rest of us there is no easy way for file-based standards conversion!
    At least not with acceptable quality. It’s a shame!
    So the fastest way would be:
    – simply use Adobe ME for scaling and encoding
    – put the MPEG2 quality specs to the max (two pass VBR)
    – process in 32bit float precision and with maximum render quality
    Do NOT de-interlace. AME’s de-interlacing is a catastrophe.
    for the best affordable quality:
    – use your Matrox or AJA I/O HW, better a BMD Teranex for scaling HD to SD
    (requires 2nd capture/playout device like computer / deck / recorder;
    We actually do have excellent scalers in our I/O-HWs but aren’t able to use them file-based!…)
    – re-capture SD uncompressed 10bit
    – encode in Apple Compressor using the CCEmp plugin
    Best regards,
    Bernhard
    P.S.: Please does anyone have an idea why file-based high quality standards conversion
    is still not available to the rest of us?
  • Dave Simpson
    September 22, 2012 at 1:22 pm
    Hello Bernhard
    Thanks for the response. I will try your Adobe ME suggestion first and see how things look, then take it from there.
    cheers
    Dave
