  • Posted by Jimena Mora on May 5, 2012 at 11:05 am
    Hello
    I would like to know if it is possible to export a FCP project into DCP format? I think I would need to use other software to make a conversion. Anybody knows what is the best way to do it?
    Thanks in advance
    Jimena
    Stephen Smith replied 14 years, 4 months ago 3 Members · 5 Replies
  • Andrew Rendell
    May 5, 2012 at 1:23 pm
    FCP doesn’t export to DCP.
    The subject has come up before though, so I’d recommend you go to the main forums page https://forums.creativecow.net/ and type DCP into the search panel and have a trawl through the responses there.
  • Jimena Mora
    May 5, 2012 at 6:07 pm
    Thank you Andrew! Do you know which software I could use to convert the FCP project into DCP format?
  • Andrew Rendell
    May 6, 2012 at 10:06 am
    Take a look at Wraptor, although other software is available. There are variatons in DCP, so have a good read up on it before you proceed.
    TBH, it’s the kind of thing that I go to a facility to get done as don’t do enough to make it worthwhile gearing up for it.
  • Jimena Mora
    May 7, 2012 at 7:58 am
    Thank you Andrew I will take a look at Wraptor!
  • Stephen Smith
    May 7, 2012 at 3:54 pm
    I’ve done DCP files at a local facility that has their own 2K projector so they can verify everything looks right. It is the Color Mill: https://www.colormill.net/
    Stephen Smith
    Utah Video Productions
    Check out my Vimeo page
