DB2 format
Posted by Damonholland on January 31, 2006 at 1:38 amDoes anybody know about rendering a vegas file into a DB2 format? I am not familiar with this format, but have been asked if I was capable of rendering my vegas project into this format.
If this is not possible, what is the highest definition format that I could use?
Rob Mack replied 20 years, 7 months ago 4 Members · 6 Replies -
Rob Mack
January 31, 2006 at 5:38 amIf you do a google search the most common thing that comes up is IBM’s database format. Evidently there is a video extension for it and that extension will handle several file types.
Is this what you’re talking about?
Rob Mack
Damonholland
January 31, 2006 at 2:07 pmYeah, that is what I came up with, but I am not sure what they are really talking about. I guess I will have to look more into it. Thanks for your assistance.
The short video that I have made is going to be a part of a compilation dvd and when I asked what format they would like my master in they said DB2. I am not familiar with this format.
Any suggestions on what the highest quality of render I could give them would be?
Thanks again
Gary Kleiner
January 31, 2006 at 5:00 pmI think they meant MPEG2.
The highest quality depends on what’s really going to happen to the file in the end. If it’s Mpg2, then your best best is to provide a one-generation render to that format.
There are also uncopmpressed formats to choose from, which could serve you well if file size is not a factor.
Gary Kleiner
Learn Vegas and DVD Architect
http://www.VegasTrainingAndTools.com
Damonholland
February 2, 2006 at 3:55 pmI am not sure what the final format will be. I know that my video will be a part of a compilation dvd. I received the message through email and it was DB2, but the email was most likely second hand information, so I could see where the mistake was made.
If size isn’t an issue, what are the uncompressed formats that I could use?
Rob Mack
February 5, 2006 at 11:27 pmIf size weren’t an issue you’d output an uncompressed AVI file. However, I’m sure that size will be an issue if you hand them a 300GB render. (just making that number up, btw).
I think you can safely go back to them and ask them for their delivery requirements. Tell them you don’t know what they mean by a DB2 format. In fact, respond to their email where they asked for a DB2, so they can see that they asked for it.
Rob Mack
