Activity › Forums › DaVinci Resolve › Davinci Running Out Of Memory.
  • Davinci Running Out Of Memory.
    Posted by D.j. Goller on August 22, 2011 at 1:50 pm
    I am in the middle of grading a 90 minute feature shot on RED, and grading @ 2k. I have broken the film into 5- 20 minute or so reels. And I am reconnecting to the r3d files. In order to not have to dig thru 13 Terrabytes worth of raw footage and manually add just the clips used for each reel. I loaded all of the raw into the media pool and let the EDL find and load the footage in the session. Now that all of the footage is in the session for each chunk of the movie. Does anyone know if there a way to remove the unused clips from the media pool so I am not blowing up the system and getting Davinci is running out of memory errors?
    D.J.
    D.j. Goller replied 15 years, 1 month ago 4 Members · 5 Replies
  • Kevin Cannon
    August 22, 2011 at 2:18 pm
    In the media pool you can sort by “usage” (you may have to right click and “update” to see the usage numbers) and then you should get a lot of clips towards the bottom that have a usage number of 0… those would be your unused clips and you can just shift-click to select and remove them all. If that’s the same as what you mean.
    KC
    prehistoricdigital.com
    hardworkingpixels.com
  • Toby Tomkins
    August 22, 2011 at 3:23 pm
    Good tip. Thanks
  • D.j. Goller
    August 22, 2011 at 8:24 pm
    Resolve breaths a sigh of relief with RAM to spare!! And my blood pressure just came back down to a manageable level!
    Thanx,
    D.J.
  • Eric Rosen
    August 23, 2011 at 7:00 am
    Does anyone know what the cause of the Out Of Memory warnings are.
    Eric Rosen
    Lightpress Inc.
    http://www.lightpress.tv
    p. 206.462.4717
  • D.j. Goller
    August 23, 2011 at 11:46 am
    The fact that Resolve is still a 32 bit app is one cause.
