Activity Forums DaVinci Resolve Davinci resolve problems with sound in 24 psf
  • Davinci resolve problems with sound in 24 psf
    Posted by Emil Eriksson on December 9, 2011 at 9:05 am
    Hi all,
    I have some problems getting the sound right when I’m running a 24psf project.
    Sound starts on the exact same frame even if a put different timecode in Audio option.
    I tried this with 25 psf and It works perfectly.
    The reason I want 24psf to work is because the clients really want it.
    Otherwise I would just run 25.
    I run DPXs in HD and the sound comes from the SDI signal.
    Have anyone else had the same issue?
    Joseph Owens replied 14 years, 9 months ago 2 Members · 1 Reply
  • Joseph Owens
    December 9, 2011 at 4:04 pm
    [Emil Eriksson] “Sound starts on the exact same frame even if a put different timecode in Audio option.”
    Have you attempted to adjust the synchronization value? Is the timecode frame rate set correctly?
    jPo
    You mean “Old Ben”? Ben Kenobi?
