Activity Forums DaVinci Resolve Davinci Resolve GPU
  • Jed Weintrob
    February 17, 2013 at 2:55 am
    Question: Other than the boot screen, what is the difference between using a stock GTX 570 card (I’m using the EVGA GeForce GTX 570 HD Double Shot 1280 MB GDDR5 PCB PCI-E 2.0 Graphics Card 012-P3-1577-KR) and using the one that’s tweaked by MacVidCards?
    I’m running 10.8.2 on a MacPro 5,1 with a GT120 as GUI
    As far as I can tell, the performance should be the same from both my card and the MacVidCards one, but I’ve recently heard otherwise.
    Jed
  • Margus Voll
    February 17, 2013 at 7:38 am
    To be precise then stock versions data bus runs at 2,5 gig
    macvids runs 5 his.
    Margus
    https://iconstudios.eu
    https://vimeo.com/iconstudioseu/videos
    DaVinci 9, OSX 10.7.4
    MacPro 5.1 2×2,93 24GB
    GTX 470 / Quadro 4000
    Multibridge 2 Pro
  • Jed Weintrob
    February 17, 2013 at 6:30 pm
    Ok. But how does that translate into speed in resolve (faster bus does not always equal faster performance, depending on overall data flow)??
  • Eric Hansen
    February 17, 2013 at 7:49 pm
    hey Jed
    from what Juan has told me, when running them as GPU cards and not GUI cards, there is no difference between the PC cards and the flashed cards from Macvidcards.
    e
    Eric Hansen
    Production Workflow Designer / Consultant / Colorist / DIT
    https://www.erichansen.tv
  • Deleted User
    February 17, 2013 at 10:22 pm
    Eric,
    Am I wrong that the GTX570 takes up two slots in a Mac tower? I currently need two slots for RAID card and BM HD-SDI card. If I keep ATI 5770 for GUI, what would be my options for CUDA card?
    Lee
    SAMDOG Digital Post
    Calgary, Alberta
    Mac Pro 2.66 12-core 16gb ram • FSI LM1760W Monitor • Matrox MX02 or BM Decklink • Caldigit HDPro2 8tb Raid • Avid Artist Transport • MC6, FCP7, PremierePro, Resolve.
    • Living my life one frame at a time •
  • Eric Hansen
    February 18, 2013 at 2:48 am
    yes, the 570 needs a double wide slot, as does the 5770. i had a similar issue, so i replaced the 5770 with a GT120, which is a single slot. it’s a step down for sure, and i’ve been thinking about getting a Quadro 4000 (single slot) with a second power supply to replace it.
    also, most RAID cards need an 8x slot. slots 3 and 4 on the Mac Pro are 4x, so your RAID card won’t run at full speed.
    e
    Eric Hansen
  • Juan Salvo
    February 18, 2013 at 3:40 am
    It depends on your model but I believe on the mac pro 4,1 5,1 slot 3 is x8.
    Colorist | Online Editor | Post Super | VFX Artist | BD Author
    https://JuanSalvo.com
  • Deleted User
    February 18, 2013 at 5:39 am
    Eric,
    I’m using a Caldigit RAID where all that’s in the Mac tower is a PCIe card. The controller is in the RAID. I’m getting around 700mb/s Read/Write.
    I’ve been using Symphony up til now for grading which is convenient for staying in the NLE. But I’m sure enjoying Resolve even with the ATI card.
    Lee
    SAMDOG Digital Post
    Calgary, Alberta
  • Eric Hansen
    February 18, 2013 at 8:39 am
    on my 3,1 and 4,1:
    slot 1: 16x (double width)
    slot 2: 16x (single width)
    slot 3: 4x
    slot 4: 4x
    pretty sure the 5,1 is the same.
    e
    Eric Hansen
  • Eric Fiegehen
    February 19, 2013 at 8:13 pm
    FYI – Cubix’s 3m limit on cable length upgrades is due to PCIe spec (and physics) limitation on 16-channel signal extension via copper cabling.
    When / If Cubix figures out a way to put all 16-channels of native PCIe bus signal through fiber optic, that would not only be a really cool solution to present, but also make your workstation environment much quieter. We’re talking distances supported of up to hundreds of meters between Cubix device and Mac Pro.
    Regards,
    Eric Fiegehen
    Cubix
Page 3 of 4
