Activity Forums DaVinci Resolve DaVinci Resolve 14 beta 4 released
  • DaVinci Resolve 14 beta 4 released
    Posted by Peter Chamberlain on June 16, 2017 at 1:11 am
    We are pleased to announce the release of DaVinci Resolve 14 beta 4. This is a no cost update for existing customers and you can download from https://www.blackmagicdesign.com/suppor … and-fusion
    Please note that this releases includes a mandatory firmware update for the DaVinci Resolve Micro and DaVinci Resolve Mini panels. The panel firmware cannot be downgraded to an older version once it has been updated and It will no longer work with older versions of DaVinci Resolve and DaVinci Resolve Studio.
    Details for 14b4
    Added support for audio cross fades
    Added support for AU plugins on Mac
    Added support for Tone Mapping from Timeline to Output Color Space in Resolve Color Management
    Added support for Tone Mapping in the ResolveFX Color Space Transform plugin
    Added support for decoding clips from the Canon C200 camera
    Added support for drop frame timecode when performing a 3:2 pull down
    Added support for selecting all clips in the Color page using Command/Ctrl+A
    Added support for smaller Media Pool floating windows
    Added support for locking tracks in the Fairlight page
    Added support for decoding and encoding 32-bit float wave files
    Added menu options and shortcuts for marking and clearing split Video and Audio In and Out marks
    Added menu option and shortcut for creating a Subclip
    Added support for Live Preview of clip thumbnails in the Media and Edit page source viewers
    Added support for hardware accelerated H.264 decoding when using NVIDIA GPUs on Linux and Windows
    Added support for Rec.2100 metadata on QuickTime renders
    Added support for new Four Color Gradient generator
    Added JKL playback support when in Cinema mode
    Added support for QuickTime reference movies on Linux and Windows
    Added support for automatically searching the current folder when a QuickTime reference clip is not found
    Force Conform has been renamed to Conform Lock
    Modifying default keyboard mapping presets are now automatically stored as Custom
    Improved performance when loading Gallery stills
    Improved Re-conform from Bins to add support for selected clips or all clips
    Improved On/Off indicator for elements in the Inspector
    Improved H.264 multiples encoding progress indicator on Mac
    Improved scrolling on timeline when using Alt/Option + mouse wheel to scroll
    Improved on-screen controls for ResolveFX Warper
    Improved application shutdown time
    Addressed an issue where project may no longer be listed when enabling Collaboration on a project with backups
    Addressed an issue with Micro and Mini panels not working on Windows 10 machines with secure boot
    Addressed an issue with rendering large WAV files
    Addressed an issue with audio and video sync on H.264 recordings from phone cameras
    Addressed a crash on the Fairlight page when using 4:4:4 monitoring
    Addressed an issue where clicking on a clip in the Color page timeline would cause a crash on Linux
    Addressed an issue with listing all the layers in a multi-part EXR
    Addressed an issue where copying and pasting projects between databases would not bring stills over
    Addressed an issue where ARRI ProRes files with flip or flop applied would import without them
    Addressed an issue where some WAV files would not get Archived or Media Managed correctly
    Addressed an issue with crashes on some Power Curve windows with tracking applied
    Addressed an issue where the Camera Shake stutter increased over time
    Addressed an issue where audio cannot be heard in Cinema Mode in the Media page and Edit page source viewer
    Addressed an issue with importing Sync clips inside Multicam clips from FCP X
    Addressed an issue where resizing a freeze frame would sometimes snap to a single frame
    Addressed an issue where running OpenCL on certain systems caused a crash on startup
    Addressed an issue where switching to the Color page in dual screen mode would cause a crash
    Addressed an issue with system running out of GPU memory when using NVIDIA GPUs in OpenCL mode on Windows
    Addressed an issue with XML import in a mixed frame-rate project
    Addressed issues with issues with Mirror, Ripples and Vortex plugins
    Addressed an issue where clips do not honor the track color on the Edit page
    Addressed an issue where it was not possible to apply node sizing in the Timeline grade
    Addressed an issue where adjusting the smoothness slider on the classic stabilizer was not changing the value
    Addressed an issue where editing some multicam clips would cause a crash
    Addressed an issue where editing an audio clip would move it to a new layer in the track
    General performance and stability improvements
    Peter Chamberlain replied 9 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
