Activity › Forums › DaVinci Resolve › DaVinci Lite file splitting issue
  • DaVinci Lite file splitting issue
    Posted by Set Shuter on May 10, 2013 at 10:08 pm
    I am using DaVinci Resolve Lite 9 for mac and am trying to split a clip I was given for a short I am correcting. I go through the usual menu to select an EDL file and after it asks for the frames per second it just does nothing.
    It was shot on a 5D mk 2 and was edited on AVID. The file is a quicktime DNxHD and my computer is a brand new iMac. I have attempted to install the codec package from AVID but it continues to fail.
    Any help would be greatly appreciated!
    Set Shuter replied 13 years, 4 months ago 4 Members · 4 Replies
  • Peter Chamberlain
    May 11, 2013 at 3:46 am
    Resolve ships with the dnxhd support so u don’t need a seperate codec install. If u manually place the big clip into the media pool, can you play it?
    If so, then try to use the edl for a preconform workflow. Details in the manual.
    Peter
    Peter
  • Juan Morales
    May 11, 2013 at 9:34 am
    The problem is that Davinci only works with the DNxHD codec as long as it’s in a MXF container. It doens’t recognize the codec when in a QuickTime MOV file…
  • Paul Provost
    May 11, 2013 at 6:59 pm
    I thought 9.1.1 added dnxhd mov support
    http://www.4Kfinish.com | owner-colorist | Hollywood, CA
    http://www.facebook.com/4kFinish
  • Set Shuter
    May 16, 2013 at 12:50 pm
    Thank you it worked!
