Activity Forums DaVinci Resolve Davinci Can’t see MXF
  • Davinci Can’t see MXF
    Posted by Jules Bodenstein on April 28, 2011 at 11:02 am
    I am having issues trying to get DaVinci to read MXFs. I understand that for compatibility with DNxHD codec DaVinci needs a plugin however I am having issues regardless of the MXF codec.
    I have created AFFs which reference MXFs in a verity of codecs which davinci supports (AVC, Uncompressed, XDCAM etc) yet DaVinci will not recognise any of these MXFs as compatible media files.
    I am assuming this is a problem arising from our set up and/or workflow but cannot see where it is breaking down, does anyone have experience of this problem or can suggest a solution?
    cheers
    Gaz Evans
    Workflow Technician
    The diROOM
    https://www.diROOM.com
    Nathan Grout replied 14 years, 9 months ago 4 Members · 3 Replies
  • Pedro Saboya burgos
    December 9, 2011 at 5:58 pm
    having the same problem here. Funny thing is that it actually sees the .MXFs of older, Media Composer 5.0 projects… but the ones I’ve transcoded in MC 5.5 are invisible to DaVinci
    did you find a fix for this?
    Pedro Saboya Burgos
    Assistant Video Editor
    Video Editor
  • Rohit Gupta
    December 10, 2011 at 10:26 am
    What codec are you using for the MXFs?
  • Nathan Grout
    December 10, 2011 at 9:02 pm
    I just did an AAF export where I consolidated to a folder and transcoded to DNxHD. I moved the resulting Avid MediaFiles folder into my DaVinci Media Pool folder and then imported the AAF. Everything seems to be working.
