Activity Forums DaVinci Resolve Davinci and mini monitor – interlaced output only???
  • Davinci and mini monitor – interlaced output only???
    Posted by Felix Frank on February 23, 2017 at 3:19 pm
    I am working on a project with was shot with the RedOne 24fps in 4K
    I have my Timeline resolution set to HD for playback reasons. The only options which work for me for video monitoring with the blackmagic mini monitor in HD i50, HD i59,94 and HD i60.
    Am I something missing here or is what the mini monitor only can output???
    cheers
    ff
    Dmitry Kitsov replied 9 years, 6 months ago 2 Members · 1 Reply
  • Dmitry Kitsov
    February 23, 2017 at 5:13 pm
    Hello, Felix,
    Most likely this indicates that the monitor you are outputting to is only capable of 1080i59.94, 60, 50.
    Both UltraStudio Mini Monitor and DeckLink Mini Monitor are capable of:
    SD Format Support
    525i29.97 NTSC, 625i25 PAL
    HD Format Support
    720p50, 720p59.94, 720p60
    1080p23.98, 1080p24, 1080p25, 1080p29.97, 1080p30
    1080PsF23.98, 1080PsF24, 1080PsF25, 1080PsF29.97, 1080PsF30
    1080i50, 1080i59.94, 1080i60
    With the new DeckLink Mini Monitor 4K also adding support for
    1080p50, 1080p59.94, 1080p60
    as well as UHD and 4K
    Ultra HD Format Support
    2160p23.98, 2160p24, 2160p25, 2160p29.97, 2160p30
    4K DCI Format Support
    4K DCI 23.98p, 4K DCI 24p, 4K DCI 25p
    Dmitry Kitsov,
    Blackmagic Design technical support agent
