Activity › Forums › Apple Final Cut Pro Legacy › Data Recovery
Data Recovery
Posted by Richard Clark on December 13, 2009 at 9:54 pmAny thoughts, ideas on Data recovery, I found a conversation back in 2004 but times have changed I believe. I have ‘lost’ 220 hours of media on my new 4tb G-Tech, ouch. I have tried TechToolPro4 which I ran for 7 days 🙂 it showed me the media but when I went to open the files it told me they were not movie files, gulp.
Richard Clark’s kiwicafe.com
Film Editor | Photographer | Writer
https://kiwicafe.blogspot.com/
Featherston AotearoaRafael Amador replied 16 years, 7 months ago 5 Members · 12 Replies -
Shane Ross
December 13, 2009 at 10:28 pmDo you have the master tapes? Master tapeless backups?
Project file?
Shane
Read my blog, Little Frog in High Def -
Richard Clark
December 13, 2009 at 10:41 pmthanks shane, yes, all my tapes are available and the project file was saved to my backup drive, I just never gave it a thought to back up the media. So if the worst comes i can simply spend the . . . time to re-ingest. Bugger 🙂
Featherston Aotearoa -
Shane Ross
December 13, 2009 at 10:45 pmYeah, the time and money spent on trying to recover the footage, and the sketchiness of how well it will be recovered might not be worth it. But that’s a LOT of hours.
RAID 5…worth the money.
Shane
Richard Clark
December 13, 2009 at 10:48 pmmany thanks Shane, I am sort of coming to that conclusion myself, bite the bullet and spend the time on uncompromised media and then make sure I have a back up. I will check out Raid5, cheers, Richard.
Jerry Alto
December 14, 2009 at 12:28 amRichard- Are the drives still spinning up? Have you tried Disk Warrior? Many of us here have used it successfully.
Jerry
G5 Dual 3GB Ram
FCP Studio 6.02
External 1 TB SATA Raid 0
Kona LH, Second system w AJA ioLA
Sony Z-1
GV-HD700 -
Richard Clark
December 14, 2009 at 12:44 amyep, like my brain they continue to spin, yep, Disk Warrior, everything I can think of . . . I guess I am putting off the inevitable, redigitize! thanks for all your thoughts though, Richard.
Jerry Alto
December 14, 2009 at 2:03 amRichard- Ok, you are at the end of the road. I presume your 4 tb G-Tech is Raid 0. Because you say the set-up is new you probably have one failing drive. If you can isolate the bad drive here is a link for some last resort remedies;
<https://www.datarecoverypros.com/hard-drive-recovery-freeze.html>
Good luck!
G5 Dual 3GB Ram
FCP Studio 6.02
Sony Z-1
GV-HD700 -
Richard Clark
December 14, 2009 at 3:04 amthanks Alto, whew, that is some read, a bit beyond my brain I am afraid. i guess I will back up the project, save to another drive, delete everything on that drive, give it a clean via techtool and redig, see you all in a month or so 🙂
Richard Clark
February 18, 2010 at 12:24 amI found the QT Files, they all look good, correctly labelled but when I went to open them was told they were not Movie files and would not open. Any ideas, otherwise i will simply bite the bullet and start over, bugger 🙂
David Roth weiss
February 18, 2010 at 12:43 amRichard,
Unfortunately, from your description it sounds as if the files have been corrupted or that only their header info still exists.
I have seen the same thing many times when various apps are used to try to resurrect drives that have gone bad. The files somehow return and give false hope, but they are sadly just shells of the former video files and wind up being worthless.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
