Activity › Forums › Apple Final Cut Pro Legacy › Data Recovery
  • Richard Clark
    February 18, 2010 at 1:09 am
    many thanks for the quick reply David, however, I now have a feeling it is the drive that has a problem as I just ingested 22 clips of video to the same drive, tried to open the QT files, same message as before comes up. They play fine in the browser window which is weird. Now I am transfering/restoring, via disk utility, all the original files from one drive to another, just as a test. I have two G-Tech drives that are exactly the same but with different Raid. I may have to get the NZ supplier to copy the material to their drives and then thoroughly reset or replace the faulty ones. I have no idea 🙂 if this makes any sense but it’s worth a try, cheers, Richard.
    Richard Clark’s kiwicafe.com
    Film Editor | Photographer | Writer
    https://kiwicafe.blogspot.com/
    Featherston Aotearoa
  • Rafael Amador
    February 18, 2010 at 1:17 am
    No TechTools neither DiskWarrior are data recovery applications.
    Run DataRescue, FileSalvage or any other application designed to do that.
    They will be able to recover your QT files even if they have been deleted, are corrupted, have not header, or whatever.
    Rafael
    http://www.nagavideo.com
Page 2 of 2
