Activity Forums Adobe After Effects Dark colors to black and bright to white
  • Dark colors to black and bright to white
    Posted by Justin Huss on May 20, 2009 at 7:50 am
    I am trying to “snap” colors either to black or white. I am using my layer as a displacement map but there is still some subtle noise in the almost black area which gives me unwanted displacement!
    I want to turn dark areas to a full black 0, 0, 0! Is there any effect that can achieve that?
    Cheers,
    Justin
    Justin Huss replied 17 years, 3 months ago 2 Members · 2 Replies
  • Curious Turtle
    May 20, 2009 at 1:16 pm
    Use the Color Correction > Levels filter. Simply take the Input Black up (drag the top left arrow to the right) and this will clip your blacks to the desired level.
    You can also do the same with your whites (top right arrow).
    Hope that helps,
    Ben
    Curious Turtle Professional Video
    Training | Editing |Support
    http://www.curiousturtle.com
    Just out: Rock Steady : Successful Motion Tracking in Mocha & After Effects
  • Justin Huss
    May 20, 2009 at 2:02 pm
    Oh yeah Ben it does help!
    I did use that one but I probably was too tired to tweak it properly! Now it works 🙂 Hopefully this post will be useful for other beginners…
    Cheers!
