Activity Forums VEGAS Pro Dance DVD Edit – your thoughts on workflow
  • Dance DVD Edit – your thoughts on workflow
    Posted by Thoreau Bakker on January 30, 2013 at 5:21 pm
    Hi All,
    I’m helping a woman edit together pieces of artistic dance footage, to make a small 5 minute piece for her to submit for a grant application.
    It should be a pretty simple task (she’d like about 10 different sections, 5-20 seconds each).
    The trick is, all files are on two standard DVDs.
    I’ve searched the forum for info on .VOB, also on DVD shrink etc etc (to combine in one file)but have been a bit stuck. I copied over all the DVD files, and was able to open them in the Vegas timeline, but trying to reopen the project today, it just takes too long to load (currently at 50% after 15-20 minutes on my workstation as I write this).
    DVD shrink wouldn’t load (was reading on other threads here about that – something about ff show or something), and the issue is, it’s taking a long time to load all the .vob / .mpg into the timeline, for me to then to be able to get to these short clip ranges.
    My system is not a beast (6 gigs of ram), so I’m looking for resource light ideas to achieve this task.
    Any tips on my current situation from people who have overcome similar challenges would be greatly appreciated (maybe an app that extracts certain time code ranges from a DVD and converts it to a good intermediary codec?)
    Thanks CC!
    -T.
    Mark Barton replied 13 years, 7 months ago 2 Members · 3 Replies
  • Mark Barton
    January 30, 2013 at 6:17 pm
    Did you do File/Import/DVD Camcorder disk? This will import the media files from an unprotected DVD so you should be able to edit them normally.
  • Thoreau Bakker
    January 30, 2013 at 8:43 pm
    Thanks for the reply.
    I noticed John mention that in a previous thread.. I had already copied over the .VOB to a folder, and tried to navigate to that folder through the DVD / Camcorder disk aread to no avail..
    I’ll try and do it from the original disc now.
    -T.
  • Mark Barton
    January 31, 2013 at 12:09 am
    I just tried it today from a DVD I made, and it imported a series of mpg media files (video and audio combined). What happens again when you try? I guess if it does not import anything, then does the DVD have copy protection on it?
    I guess if it is not copy protected and that still did not work,you could try to play the DVD and screen record the sections you need to save as media to edit.
