Activity Forums Adobe After Effects Dan-Expression for Counting
  • Dan-Expression for Counting
    Posted by Tom Daigon on July 16, 2005 at 5:00 pm
    Hi Dan. I need a counter to count up from 7,000 to 13,000 within a 30 second period of time. It also needs to allow me to change the start, end and duration amounts. I tried altering the money counter you helped me with by deleting the last line of the expression, which deleted the “$” and the “,” , so I ended up with a counter that did not have commas (ie. 7000 as opposed to 7,000). Your help is appreciated!
    Tom
    Tom Daigon replied 21 years, 2 months ago 3 Members · 6 Replies
  • Mylenium
    July 16, 2005 at 6:24 pm
    Hi, I’m obviously not Dan, but I’ll give it a try.
    start_value=7000;
    end_value=13000;
    ani_time=30;
    diff_value=end_value-start_value;
    time_value=diff_value/ani_time;
    out_value=time_value*time;
    [out_value]
    Apply this as usual to the source text property.
    Mylenium
    [Pour Myl
  • Tom Daigon
    July 16, 2005 at 7:33 pm
    Thanks Millenium, but no go. I copied and pasted the expression to the text property and it starts
    counting at 0 and ends at 994.00000000 with lots of places following after the decimal.
    Dans expression for the money counter is this…
    This is an expression for the source text of a text layer that should do the trick. Use a monospaced font or set kerning to 0:
    startValue = 64122205;
    endValue = 85302264;
    dur = 30; //seconds
    s = “” + Math.round(linear(time,0,dur,startValue,endValue));
    “$” + s.substr(0,2) + “,” + s.substr(2,3) + “,” + s.substr(5,3)
    Tom
  • Dan Ebberts
    July 16, 2005 at 9:19 pm
    Tom,
    Try this:
    startValue = 7000;
    endValue = 13000;
    dur = 30; //seconds
  • Tom Daigon
    July 16, 2005 at 9:29 pm
    Thanks Dan. It is the same thing I tried when I deleted the last line of the Money Counter you helped me with a while back. The problem is the comma after the 1000s position (ie. 7000 vs 7,000) is gone.
    How do you add a comma to the equation…And could you give me a laymans explanation of what the expression is telling AE to do?
    startValue = 7000;
    endValue = 13000;
    dur = 30; //seconds
    Tom
  • Dan Ebberts
    July 16, 2005 at 9:53 pm
    Oh, you want the comma. I get it now. 🙂
    This should do it:
    startValue = 7000;
    endValue = 13000;
    dur = 30; //seconds
    s.substr(0,s.length-3) + “,” + s.substr(-3,3)
    It will only work for values from 1,000 to 999,999
    The tricky part of the expession is just converting the number to a string and then manipulating the string (using the JavaScript substr() method) to split the string into two pieces an stick a comma in between. You may need to dig into a javaScript reference to really figure it out.
    Dan
  • Tom Daigon
    July 16, 2005 at 10:09 pm
    Yes sir, that did the trick. Thanks for the tip on where I can get info for understanding what substrings are and what it means to split them (And this enthusiasm from someone who still has nightmares about high school math class!).
    Your help is truly appreciated.
    Tom
