Activity Forums VEGAS Pro Damn… upgrade to vegas10, now have all black screen MOV files…
  • Damn… upgrade to vegas10, now have all black screen MOV files…
    Posted by Glenn Angel on April 26, 2011 at 4:55 pm
    Subject says it all!
    I was running vegas 9 with quicktime 7.6.2 and MOV files would be fine, however the iosurrogate was having issues and the thing kept crashing… I also just wanted the upgrade so i went to vegas 10..
    First 5 files went in well, but after adding anymore all the previews go black and now the rest are all black too.
    The files are not currupt… and i know this is an issue, but i thought it was fixed in 9D and 10…
    Sooo should i revert my quicktime to another one or what!!! any ideas coz i NEED TO EDIT!!!
    Glenn Angel replied 15 years, 3 months ago 3 Members · 5 Replies
  • Mike Kujbida
    April 26, 2011 at 4:58 pm
    I’m running the latest version of QuickTime and Pro 10 with no problems.
  • Glenn Angel
    April 26, 2011 at 5:11 pm
    ok weird.
    Ive started another project and it works fine…
    howevre my old project still has blue only!! No IDEA!! wttttttt
    dunno where to go from now…
    I dont want to start working on a project.. get half way and it all go black and start again!!! what should i do!
    SHould i just export all to another format using… premiere or somthing?
    or is there a BULK export program?
    I ahve about 50 MOV files in library but only 4 in the timeline.
    Im also using Sony MTS files in same timeline.
    Also.. my IOSURROGATE seems to keep freezing >(
    Perhaps i ahve too much stuff in my library and i should move to using something like Premiere 🙁 ??
  • Glenn Angel
    April 26, 2011 at 5:39 pm
    also, just checking, which version of QT are u using.
    Im still on 7.6.2 andd the issue is so intermittent. One second they will work, next second all the time line ones are black… Next second i can see the again.
    I updated to most recent and they all went black, no luck… but maybe somewhere between 7.6.2 adn current version there is a compatible version
  • Linda O’connell
    June 4, 2011 at 3:45 pm
    Did you ever find a solution to this? I also am having the same problem. Using Vegas 8 for 5 years..never had a problem until recently.
    Also have two different computers- 32 bit & a 64 bit- neither work 🙁
  • Glenn Angel
    June 4, 2011 at 3:55 pm
    try using quicktime 7.6.2 (unisntall the other version u have).
    I found that worked for vegas 9 64x however after a while if i added more than 5 mov clips it would go bakc to failing.
    I have since bought adobe premiere and it runs like ducks nuts.
    Sad to say but vegas = fail for MOV
    They say they have “fixed” the issue in 10 (i was checking b4 buying) i downloaded a fake versiona nd no, still no luck)
    Others may say “fake version = no updates = fail”… but my gut said i shouldnt go for it and i changed :S
    Sorry i couldnt help more
