Activity › Forums › Panasonic Cameras › Damaged/ripped DVCPro HD tape – best way to capture/re-lay
  • Damaged/ripped DVCPro HD tape – best way to capture/re-lay
    Posted by Ian Liuzzi-fedun on August 24, 2012 at 11:43 pm
    I have a ripped DVCPro tape that I want to capture and then re lay back to tape. I can manually repair the tape however I am torn between capturing in DVCPro HD or through the SDI output of the deck to my capture card and then real-time transcoding to ProRes. I know at the end of the day only the most technical and sensitive will be able to tell but since this is supposed to be a master, I want the best quality possible. Would capturing as ProRes give me an more latitude and help with compression concatenation or not?
    Ian Liuzzi-fedun replied 14 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
