Activity › Forums › VEGAS Pro › Damaged GoPro file won’t open in Vegas 12 or 13
  • Damaged GoPro file won’t open in Vegas 12 or 13
    Posted by Stephen Crye on November 22, 2016 at 4:39 am
    Hi;
    Sometimes the last segment of a GoPro recording (Hero 3+ Silver 1080 60p) won’t open in Vegas. In the past I’ve been able to open it in VLC and save/convert the damaged segment to the H264 in MP4 container and then I can import it into Vegas. One clue that I will have the problem even before I try to import it is that Windows 7 will not show the thumbnail. MPC-HC and VLC play it fine.
    Tonight my VLC trick did not work.
    I suspect the damaged file was lacking an EOF or something. For the converted file, I suspect a codec problem.
    Here’s what MPC-HC reports as the properties of the VLC converted file:
    General
    Complete name : H:\SonyPMB-3\20161120-ParaglidingDry\flight2\GoPro\GP021100.MP4
    Format : MPEG-4
    Format profile : JVT
    Codec ID : avc1
    File size : 1.15 GiB
    Duration : 6mn 58s
    Overall bit rate mode : Constant
    Overall bit rate : 23.6 Mbps
    Encoded date : UTC 2016-11-20 15:32:02
    Tagged date : UTC 2016-11-20 15:32:02
    AMBA :
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : Main@L4.2
    Format settings, CABAC : Yes
    Format settings, ReFrames : 1 frame
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Duration : 6mn 58s
    Bit rate mode : Constant
    Bit rate : 23.4 Mbps
    Nominal bit rate : 25.0 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 59.940 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.189
    Stream size : 1.14 GiB (99%)
    Title : GoPro AVC
    Language : English
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio
    Format : AAC
    Format/Info : Advanced Audio Codec
    Format profile : LC
    Codec ID : 40
    Duration : 6mn 58s
    Bit rate : 128 Kbps
    Channel(s) : 2 channels
    Channel positions : Front: L R
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Stream size : 6.38 MiB (1%)
    Title : GoPro AAC
    Language : English
    Any help greatly appreciated. The file is the last segment of a paragliding flight from my helmet mounted GoPro, so I’t cant be easily re-shot!
    Steve
    Win7 Pro X64 on Dell T7500, MultiTB SATA, 12GB RAM, nVidia Quadro 2000, Vegas 12, 11, 10, 9 DVDA 6.0 & 5.2(build 135) Sony HDR-CX550V, Panasonic GH3 with LUMIX G X VARIO 12-35mm / F2.8 ASPH, LUMIX G X VARIO 35-100mm / F2.8
    Nigel O’neill replied 9 years, 10 months ago 3 Members · 6 Replies
  • Ole Kristiansen
    November 22, 2016 at 5:56 am
    Can you open the file in the GoPro Studio app ?
  • Stephen Crye
    November 22, 2016 at 6:01 am
    The GoPro Studio program caused huge problems on my Windows 7 machine. I forget what they were – I had to struggle for days to excise it from my system. It broke other programs in a very subtle way and was a total cluster foxtrot. I think it was related to the codecs it installed. It’s never going back on my computer.
    I can open the damaged file fine in lots of players, just not in Vegas.
    Steve
  • Stephen Crye
    November 22, 2016 at 6:12 am
    This software will “fix” it so that it at least can be imported, but the resultant file has dropouts, stutter, other problems.
    https://grauonline.de/cms2/?page_id=5
    Steve
  • Ole Kristiansen
    November 22, 2016 at 6:58 am
    Maybe you can open your file in Handbrake and then convert it !
  • Stephen Crye
    November 25, 2016 at 2:06 am
    I think I need to try Handbrake, have read about it, but never used it.
    Do you know if it can provide a missing EOF?
    Stev
  • Nigel O’neill
    November 28, 2016 at 9:58 pm
    You could use Handbrake just to grab what you need i.e. cut and render out a section of video.
    I do recommend running MalwareByte’s AntiMalware afterwards. I did notice severe performance issues on my machine after installing Handbrake, like Handbrake would load or would not close after loading, PC became unresponsive, task manager would not run. Malwarebytes found some nasties lurking in my system and removed them. I still use handbrake without issues now. It might have been a huge coincidence or I had something pre-existing on my system already that really upset Handbrake. All other programs otherwise ran fine, including Vegas.
    My system specs: Intel i7 970, GTX570, 12GB RAM, ASUS P6T, Vegas Pro 12 (x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
