Activity Forums Adobe After Effects Damaged AEP?
  • Damaged AEP?
    Posted by Steve White on April 4, 2011 at 5:57 am
    Hi All
    I keep getting this message every time i try to render.
    After Effects error:Rendering erroR while writing to file
    “F:\Comp1.mp4”.Unknown Error! (-1610153453)
    Had been rendering this file all afternoon adding a bit more then rendering it again.Until i got this message that is.
    I can load and render other files but not this one anymore.
    I will load and play on the timeline OK.
    Could i have damaged it in some way? and if so is there any way to fix it?
    I have a quad core 3.0 extream with 8 gig of ram and loads of space on my HD.
    thanks yours
    Stephen White.
    Diego Alvarado replied 12 years, 4 months ago 4 Members · 5 Replies
  • Steve White
    April 4, 2011 at 9:50 pm
    Hi Dave
    and thanks for your fast reply
    Multiprocessing is turned off and so is open GL now.
    sorry but i did not mention that i,m useing CS5 and i do have 1 footage
    imported into AE its on video copilots Evolution DVD and its format is .MOV the rest are .PNG files.
    I was quite happerly rendering all afternoon yesterday adding more and rendering again to see the result.The last thing i added was just more text.
    When i render now as an AVI file it takes just one second to render and only renders a split second.I am no longer getting the ERROR Message.
    yours
    Stephen White.
  • Steve White
    April 5, 2011 at 1:40 pm
    OK PROBLEM SOLVED
    Some how i have managed to slide the work area down to nothing.Hence the error message.
    Feel a fool but also feel a bit wiser in AE.
    thanks for your input Dave
    Stephen White.
  • Oliver Granlund
    July 5, 2011 at 10:54 am
    The composition what im working on is 10 minutes and 30 seconds long 1080p 60fps footage
    for some reason i always get the error (-1610153453)
    I saw your post where you have quted Dave Stock’s answer
    The thing is that all the video clips in my video are mp4 files
    so what should i do?
    remake the whole thing or…?
  • Santiago Dutil
    September 22, 2012 at 9:32 am
    Hi Dave,
    First thanks due you help me many times.
    To everyone that have the problem error (-1610153453)
    In my case I solved the problem so simple:
    By changing the destination folder, I was rendering in a folder with a non english character! in my spanish language we have the “Ñ” (‘n’ with a wave on top ) after effects mp4 codec NO Ñ or cyrillic, etc…
    Hurry up render output to desktop… done! 🙂
    Hope it would helps
    Santiago
  • Diego Alvarado
    April 7, 2014 at 5:52 am
    THE SOLUTION IS rendering to a path that does not contain spaces nor special characters (like underscores or hyphens), FOR INSTANCE:
    C:\yourvideo.mp4
