Daisy chaining two or more external drives for HDV
Posted by Charles Avanti on June 24, 2006 at 6:45 pmI found this information about Firewire vs. USB2
https://www.usb-ware.com/firewire-vs-usb.htmDoes anyone here capture & edit HDV with external drives successfully? If so, what’s your configuration?
I would like to use several external drives to capture and edit HD video.
Is it possible to connect and run two or more Western Digital My Books simultaneously by daisy chaining them VIA Firewire, or does each drive need it’s own Firewire connection to the computer? If so, will there be any speed decrease? And, does each drive need to be plugged into the A/C power?Thanks.
Charlie
Jerry Waters replied 20 years, 2 months ago 5 Members · 13 Replies -
Charles Avanti
June 25, 2006 at 4:25 pm -
Charles Avanti
June 25, 2006 at 7:21 pm -
Sada
June 26, 2006 at 2:16 amThe enclosures I use have two firewire ports—Lets say I have three externals—One drive goes directly into my computer via the firewire port. The second cable goes from drive one (second port) to drive two. The third cable goes from drive two to drive three.
I capture directly from my deck or camera to my firewire card—-then to whichever directory I chose in any of the drives. By the way, I use HD Connect by Cineform to capture all my files. As far as enclosures go, I like the ones that Granite Digital makes—-The only problems I have ever had is with controller cards built into the units and I think that Granite’s are fairly reliable. I’m sure other people have other ideas.
Charles Avanti
June 26, 2006 at 2:51 am -
Gary Kleiner
June 26, 2006 at 4:26 am -
Peter Wright
June 26, 2006 at 5:08 amHi Charlie
I have 7 or 8 firewire externals daisy chained, and like Nancy I capture to whichever one I want for each project. My firewire is 400, which is plenty fast enough for HDV, which is roughly the same data rate as standard DV.
If you move into uncompressed HD you will probably need a raid to be able to handle the faster data rates.
Peter Wright
Perth, Western Oz
http://www.allroundvision.com.au -
Jerry Waters
June 26, 2006 at 1:48 pmI have 5 external drives plus a Buffalo terrabyte on my network. I started using firewire drives and still do some but mostly I now run as USB. All work perfectly and together. When all are on I have about 2.4 terrabytes online. I use Connect HD also and do exclusively HDV work (my only interest is feature movie production). Connect is the best $199 I ever spent. I don’t need proxies or swapping, it has scene detection and their files edit like they are DV in Vegas – no noticeable difference. My cameras are a Z1 and an A1U. Sometimes I shoot multicam with my friend’s FX1. Counting backup most of my space is being used at present.
JerryW
Charles Avanti
June 26, 2006 at 5:15 pmThank guys and gals for the helpful info. Some other questions come to mind:
How do I tell if my computer supports firewire 400, or 800?
I have an external firewire DVD burner attached to my old cpu, and it has its own power switch which needs to be turned on and off. Do the external firewire hard drives have to be turned on and off individually?
What are the pro/cons of going with HD-Connect by Convergent Design, vs. HD-Connect by Cineform? JerryW, I’m not sure which one you have.
Thanks.
Charlie
