Da Vinci -> Avid: MediaTool (MXF) trouble
Hello to all. This is my first post and finally i found a place where problems have solutions (most of the times).
Ok, here’s my problem (it is driving me crazy). I’ll put here step by step and I hope to get an answer and also help someone else with my same problem.
Application used: Media Composer 6.5 & DaVinci Resolve 9
1 – I export the .AAF from an Avid Sequenze(DNxHD) and all goes fine
2 – I import the sequence in Da Vinci and it is all perfect
3 – Color correction & grading time, all fine
4 – Export time. I use the AAF Avid RoundTrip, put the destination folder in MXF/1, it renders and all fine.
5 – Coming back on Avid and I prepare a new BIN for the “graded footage”
6 – Open up the Media Tool, search and find the project-name made in DaVinci for the grading
7 – It loads and…………… NOTHING APPEARS!!!!!
8 – I check the files manually and everything is there, simply media-tool doesn’t see them.
9 – If i take the files by hand it’s ok, i put on the tape name, re-link to the new footage and it’s ok.……but, Why media tool doesn’t work? Is there something i have to know? I tried all the combinations, checking all the boxes etc., but nothing. Seems that media tool is blind.
Does someone had my same problem? Is there any solution?
Thanks a lot in advance,
Roberto
