Activity Forums Adobe After Effects Expressions D. Ebberts Inverse Kinematics Redux Question
  • D. Ebberts Inverse Kinematics Redux Question
    Posted by Cutter Johnston on June 17, 2008 at 4:05 pm
    I am having real fun with this expression and set up. And one issues. I rotated the lower “limb” prior to parenting and adding the expression. It behaves oddly. The lower limb rotates around the anchor point of the upper limb. Is it necessary for all “limbs” to have a zero rotation before parenting and “expressing”?
    Cutter Johnston replied 18 years, 3 months ago 2 Members · 2 Replies
  • Dan Ebberts
    June 17, 2008 at 5:42 pm
    The expression should compensate for the original orientation. There must be something else going on.
    Dan
  • Cutter Johnston
    June 18, 2008 at 12:43 pm
    Thank you! Onward and upward.
