CYMK to RGB // Illustrator to After Effects Color Shift
I would really appreciate some insight into this issue:
I am working with a logo designed in Illustrator with CYMK colors. I need to work with this AI file in After Effects. Upon importing as a composition to AE, there is a dramatic shift in colors – which I presume is a result of After Effects interpreting the graphic in RGB. I know this to be the case since, when working in Illustrator, if I change the document colors to RGB, it looks exactly as it does once importing into After Effects.
The problem is that I need the logo to look exactly as it does in Illustrator CYMK, but in After Effects. Changing to RGB in Illustrator and then color correcting with curves or something to get back to the intended look is not an option – there must be some way to maintain the look of the CYMK logo but in RGB for AE.
Please help! This is a time sensitive project. Thank you in advance.
