Activity Forums Zaxwerks Cylinder Appears As Square In AE
  • Cylinder Appears As Square In AE
    Posted by Gregory Kuhn on June 17, 2008 at 8:25 pm
    I have created a cylinder in 3D Invigorator Pro and applied a map to one side. But in AE it continues to show as a square. Does anyone know what the problem may be. When I put it in draft mode in AE, it shows the cylinder but not in full resolution mode.
    Please help!
    Greg Kuhn
    Jon Okerstrom replied 18 years, 3 months ago 2 Members · 1 Reply
  • Jon Okerstrom
    June 18, 2008 at 1:50 am
    Hi Greg,
    Be sure you’re looking at best quality mode rather than draft and be sure the smoothness slider under “best quality” is at the small end of the scale. You’ll get even smoother results if you type in a smaller number like .01.
    Jon
