Activity Forums Adobe After Effects Cycore particle FX (AE)
  • Cycore particle FX (AE)
    Posted by Eric Neal on June 19, 2008 at 6:17 am
    Hi all. I saw Aahron’s (did I spell that right?) excellent tutorial on creating spark fx using CC’s particle playground, which was tremendously helpful. Only question I have now is how do I alter the speed at which the sparks fly? My keyframes are set just a few frames apart for a nice little burst that I want to appear quickly and begone. Looks great, except the sparks taper off at what seems much slower than a realtime effect. I’ve tinkered with every setting available but, still being a newbie at it, couldn’t figure out how to speed those sparks up to make them ‘fly away’ faster. Any help would be greatly appreciated! Thanks!
    Eric
    Eric Neal replied 17 years, 11 months ago 3 Members · 4 Replies
  • Steve Blacker
    June 19, 2008 at 6:05 pm
    I’m not in front of AE right now, but one solution that might work is to precompose it and then time remap the result to speed up those last sparks?
  • Christian Wheel
    June 19, 2008 at 7:39 pm
    Play around with the “longevity” setting.
  • Christian Wheel
    June 19, 2008 at 9:20 pm
    Oops, let me correct myself… I didn’t read your post closely enough. The “Longevity” Setting will make your particles die faster, but if you want them to actually MOVE faster you’ll need to change the Velocity under Physics.
  • Eric Neal
    June 20, 2008 at 2:50 am
    Hi Christian,
    Longevity was indeed the key. I THOUGHT the longevity only controlled the length and amplitude of the particles, which is what the velocity settings do, more or less. Anyway, I toned it way down and amped up the gravity for them to fall off-screen as desired, and it’s pretty sweet now. Thanks a lot!
    Eric
