Activity Forums Adobe After Effects Cycle FCurves
  • Cycle FCurves
    Posted by Stephan Dube on November 26, 2008 at 5:54 pm
    Id like to know if it is possible to have a cycle (loop) on a keyframe?
    for example if I have 2 keyframes of opacity (100% and 50%) and I want it to do a cycle so during the entire animation it would do it. Im sure there is a way to do it in expression but Im not that savy, for now Im uding the good old copy and paste but Im sure there must be a better way
    thanks
    stephan
    Stephan Dube replied 17 years, 9 months ago 2 Members · 2 Replies
  • Darby Edelen
    November 26, 2008 at 10:12 pm
    You’d need an expression.
    There are 2 that could be directly applicable to your situation:
    loopOut();
    and
    loopIn();
    The first will loop the values after the last keyframe, the second will loop the values before the first keyframe.
    There are several different kinds of loops:
    loopOut("cycle");
    loopOut("continue");
    loopOut("pingpong");
    loopOut("offset");
    Here’s a video that should help illustrate the differences:
    https://www.youtube.com/watch?v=OqZBh9APOww
    Darby Edelen
  • Stephan Dube
    November 26, 2008 at 11:01 pm
    thanks so much its quite an easy script 🙂
    thanks again
