Activity › Forums › AJA Video Systems › CVBS out question
  • CVBS out question
    Posted by Marc Colemont on April 30, 2010 at 10:56 pm
    I would like to connect a waveform and vector scope to the CVBS composite output while capturing in HD.
    But that doesn\’t seem to work, as the composite output only becomes active when downscaling to SD??
    Is there a certain setting that I can do instead?
    Marc Colemont replied 16 years ago 4 Members · 12 Replies
  • 12 Replies
  • Gary Adcock
    April 30, 2010 at 11:39 pm
    [Marc Colemont] ” as the composite output only becomes active when downscaling to SD??
    Is there a certain setting that I can do instead”
    nope.
    what are you using composite SD scopes for if you are not also monitoring in SD while in an HD capture?
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows for the Digitally Inclined
    Chicago, IL
    https://blogs.creativecow.net/24640
  • Marc Colemont
    May 1, 2010 at 8:15 am
    Hi Gary,
    The reason is that I have this unit, and is helpfull to check levels.
  • Marc Colemont
    May 1, 2010 at 8:55 am
    And we wanted to connect a DVD recorder on the composite output while recording in HD on the AJA Ki pro itself.
  • Jeremy Garchow
    May 4, 2010 at 1:58 am
    You can record HD and monitor SD.
  • Marc Colemont
    May 7, 2010 at 8:44 am
    I found the way to do this yes.
    – Out Convert at ‘SD’
    – Component out at ‘Out Convert”
    The analog Component is hardware related to the Composite Out since there is only one DA inside, I was told by AJA support guy. Maybe the Menu should say ‘Analog Out’ instead of ‘Component Out’ then.
    I do had to try multple times, as I only got green flickering output. (After trying and changing many settings) Rebooting the unit did the trick.
  • Paul Rozon
    September 11, 2010 at 5:26 pm
    The manual indicates that all outputs are live except for the composite out unless you are downcoverting what you are recording.
    has anyone else had success with this? It would be a huge bonus to be able to hand a client a DVD at the end of a show before taking the HD version into post production.
    Can you give more details on how you did this?
  • Gary Adcock
    September 12, 2010 at 5:12 am
    The Composite port is ONLY active when the Analog outputs are set to downconvert your footage to SD.
    gary adcock
    Studio37
    Post and Production Workflow Consultant
    Production and Post Stereographer
    Chicago, IL
  • Jeremy Garchow
    September 12, 2010 at 1:36 pm
    As has been mentioned in this thread. Set the out
    Convert to downconvert and composite will activate.
  • Paul Rozon
    September 14, 2010 at 10:06 pm
    Thanks for the info. That confirms what I already believed to be the case.
    I read the earlier thread and thought he was saying that you could record HD and still have a downconverted feed at the composite video out. Which would be nice.
  • Marc Colemont
    September 15, 2010 at 2:08 am
    Yes it does that. You can record in HD while activating the scaler in the output. It will generate a Composite signal simultaineously lile described above.
