Activity Forums Adobe Photoshop Cutting up contact sheets or tiled image?
  • Cutting up contact sheets or tiled image?
    Posted by Dustin Nelson on September 3, 2009 at 5:47 pm
    Is there a way to save basically reverse a contact sheet? Or to cut up an image into several images of a specified size?
    I have to do this for several files, so if there is an easy way to do it, it would save me a lot of time… Thanks in advance!
    Dustin Nelson replied 17 years ago 2 Members · 2 Replies
  • Theo Van laar
    September 4, 2009 at 4:35 pm
    FILE-AUTOMATE-CONTACTSHEET II
    Good Luck!
    Theo
  • Dustin Nelson
    September 4, 2009 at 4:52 pm
    Yeah, I know how to make a contact sheet, but what I want to do is take an existing contact sheet and cut it up. So that each image in a square of the contact sheet becomes a separate document.
    So as an example, having a contact sheet with 6×6 tiled images, and then being able to take that, and end up with 36 individual files, one for each tile.
    Unless I am missing something, you can only build contact sheets from Contact Sheet II, not break them down into their individual components.
