Activity › Forums › VEGAS Pro › Cutting quickly between 2 clips. 2 frame per clip.
  • Cutting quickly between 2 clips. 2 frame per clip.
    Posted by Frank Manno on April 16, 2007 at 8:25 am
    I want to be able to do some quick cuts between 2 clips and want to be able to select the amount of frames.
    Eg: 1 frame from clip 1 then one frame from clip 2 then 1 frame from clip 1 then 1 frame from clip 2.
    An old editing program I had called Speed Razor used to do this by placing a strobe transition between 2 clips and you would simply ‘strobe’ between the 2.
    Can anyone think of a good way I could do what I want, hopefully without having to use a script to actually make a whole bunch of 1 frame cuts 🙂
    -Frankie
    Edward Troxel replied 19 years, 5 months ago 3 Members · 7 Replies
  • 7 Replies
  • Gilles Pialat
    April 16, 2007 at 3:41 pm
    I made a script named
  • Frank Manno
    April 17, 2007 at 12:11 am
    Thanks! Exactly what I need. But I can’t seem to download the script.
    All I get is a .png file which is a picture. Where is the actual script?
    -Frankie
  • Gilles Pialat
    April 17, 2007 at 6:03 am
  • Frank Manno
    April 17, 2007 at 6:57 am
    Ok managed to download it but can’t get it to work.. I’m getting this error..
    Any ideas anyone??
    System.BadImageFormatException: The format of the file ‘VideoStrobe.dll’ is invalid.
    File name: “VideoStrobe.dll”
    at System.Reflection.Assembly.nLoad(AssemblyName fileName, String codeBase, Boolean isStringized, Evidence assemblySecurity, Boolean throwOnFileNotFound, Assembly locationHint, StackCrawlMark& stackMark)
    at System.Reflection.Assembly.InternalLoad(AssemblyName assemblyRef, Boolean stringized, Evidence assemblySecurity, StackCrawlMark& stackMark)
    at System.Reflection.Assembly.LoadFrom(String assemblyFile, Evidence securityEvidence, Byte[] hashValue, AssemblyHashAlgorithm hashAlgorithm)
    at Sony.Vegas.PrecompiledScriptManager.Run()
    at Sony.Vegas.ScriptHost.RunScript(Boolean fCompileOnly)
    === Pre-bind state information ===
    LOG: Where-ref bind. Location = D:\Program Files\Sony\Vegas 6.0\Script Menu\VideoStrobe\VideoStrobe.dll
    LOG: Appbase = D:\Program Files\Sony\Vegas 6.0\
    LOG: Initial PrivatePath = d:\program files\sony\vegas 6.0\script menu\videostrobe\
    Calling assembly : (Unknown).
    LOG: Private path hint found in configuration file: mediamanager.
    LOG: Policy not being applied to reference at this time (private, custom, partial, or location-based assembly bind).
    LOG: Attempting download of new URL file:///D:/Program Files/Sony/Vegas 6.0/Script Menu/VideoStrobe/VideoStrobe.dll.
  • Gilles Pialat
    April 17, 2007 at 7:04 am
    Sorry, those scripts are for Vegas7.
  • Frank Manno
    April 17, 2007 at 8:49 am
    No problems then, I’ll upgrade to Vegas 7
    Thank you for sharing your script..
    -Frankie
  • Edward Troxel
    April 19, 2007 at 3:28 am
    Excalibur can also handle this task and has been able to do so since Vegas 4.
    Edward Troxel
    JETDV Scripts
