Activity › Forums › Maxon Cinema 4D › Cutting planes
  • Adam Trachtenberg
    November 9, 2013 at 12:19 am
    You can convert the planes to polygons (make editable) if they aren’t already. Then you can go into edge mode and use the knife tool to cut lines where you need them. Then it’s just a matter of selecting the overhang polygons and deleting them.
    Or you could use a Boolean object.
