Activity Forums Adobe Premiere Pro Cutting Nested Sequence Stops Playback in Premiere
  • Cutting Nested Sequence Stops Playback in Premiere
    Posted by Justin Taylor on September 15, 2015 at 5:32 pm
    Ever since installing the most recent release of Adobe Premiere Pro CC (2015.0.2 (9.0.2 (6) Build)), it has a consistent playback issue. After about 1 minute of editing with a nested sequence, Premiere won’t allow me to playback anything from a sequence or in the source monitor (I have also tired to open numerous projects to no avail).
    The only partial-fix is to restart Premiere and edit a rendered sequence instead of a nested sequence.
    It’s a similar problem that arises when preferences are set to the incorrect audio card, but changing audio settings didn’t fix it this time, even when trying two different audio devices. I also verified permissions were set to read and write, and tried rolling back Premiere to a previous version, yet the problem persists. I rolled back to CC 9.0.0 build yet still have the problem.
    This is a timely issue as this is a company workstation and projects have deadlines.
    Any advice is much appreciated,
    Justin
    ________
    ________
    Specs:
    iMac 14,2
    OSX 10.10.4 (Yosemite)
    3.5 GHz Intel Core i7
    16 GB 1600 MHz DDR3
    NVIDIA GeForce GTX 780M 4096 MB
    Justin Taylor replied 10 years, 11 months ago 1 Member · 1 Reply
  • Justin Taylor
    September 15, 2015 at 6:16 pm
    Alright, I finally found a workaround. The sequence I was nesting must have been corrupted somehow and that was freezing up premiere each time I tried to draw it into another sequence through nesting.
    THE FIX:
    -Copy all contents from the original sequence into a new sequence (label the original sequence as corrupted)
    -Nest the new sequence into another sequence with desired settings.
    It’s cutting fine for now.
