Activity Forums Adobe Audition Cutting Long Recording into 10 minute Tracks
  • Cutting Long Recording into 10 minute Tracks
    Posted by Markofcain on May 4, 2006 at 1:41 am
    I’m using Audtion 1.5.
    I often record long lectures and then burn them out to CD or to an mp3 player for listening on the go. A single track of 60 minutes of recording has its drawbacks — but taking the time to select and copy 10 minutes at a time into the CD Project gets old real quick.
    Is there a way to automate setting a new track at every 10 minutes? Either in Edit View or CD Project View or Multitrack View?
    Willie Toth replied 20 years, 4 months ago 3 Members · 2 Replies
  • Ozpeter
    May 4, 2006 at 2:45 am
    No – but a freeware program called CueListTool has the facility within it.
  • Willie Toth
    May 4, 2006 at 10:35 am
    You can’t do it automatically, but you can do it manually on the session side … Bring your clip in, cut it at each desired length, highlight that section then do a mixdown of the highlighted wave and save … When you have done this to the whole lecture then just simply write a CD like you would a music CD using each section as a stand alone track ………. WILLIE
