Activity Forums Apple Final Cut Pro Legacy Cutting in multiple edits
  • Cutting in multiple edits
    Posted by Kevin Curran on December 6, 2007 at 11:10 pm
    I think I did this edit in an FCP class but it was a while ago and I could be wrong.
    I laid in an audio track and I hit CTRL V to make edits on the beat across the clip.
    I had about 200 edits and I wanted to take 200 stills and insert them all at once to
    cover the edits. All I get now are error messages so I’m trying to figure out what
    I’m doing wrong or if I made up this technique in my head…any info would be
    appreciated. thanks – Kevin
    Jerry Hofmann replied 18 years, 9 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    December 7, 2007 at 1:28 pm
    There’s no way to edit more than one clip at a time if you want each clip to hit a certain edit point in the audio track. Best you can do en masse is have them all be the same duration that you set stills to be in the user prefs before you import the files.
    Jerry
