Activity › Forums › Adobe After Effects › cutting a frame out of an image sequence in AE
  • cutting a frame out of an image sequence in AE
    Posted by Miles Blow on July 24, 2006 at 12:04 pm
    Hi
    Im wanting to cut a frame out of an raw image sequence in after effects. Im used to being able to do this in premiere. How do I do this in AE
    Thanks for any help!
    Miles
    Mike Morris replied 20 years, 2 months ago 2 Members · 1 Reply
  • Mike Morris
    August 3, 2006 at 8:06 pm
    Just to confirm… you have imported an image sequence into After Effects, and wish to simply remove on frame of the playback?
    If I am correct in my assumption, there’s a couple of ways, but I’d recommend going to the frame just BEFORE the frame you want removed. Hit Command+shift+D (or control + Shift + D on PC) to duplicate the layer around that point in the timeline… What that does is it cuts the clip from the original layer where the timeline marker is, and in the newly created layer, it picks up right at that point and continues until the end of the clip.
    From here, move the timeline marker to just AFTER the frame you want removed, then hit option + [ (or alt + [ on PC). Then, you just have to drag the clips together so there is no gap between the ending of the first layer, and the beginning of the second layer.
    Hope that is what you needed to know.
    Sib Ntsib Dua
    Xeeb
