Activity Forums Canon Cameras Cutting 24F in FCP – now much less painful
  • Cutting 24F in FCP – now much less painful
    Posted by Colin Mcfadden on June 22, 2006 at 4:07 pm
    With the ProApps update that shipped last night (for FCP5.1.1), you can now make a 1080p24 HDV sequence. You can also now use MPEGStreamclip to convert an m2t into a 1080p24 HDV quicktime file. So, aside from capturing the 24F directly within FCP, you can now cut footage shot 24f in FCP. Use VirtualDVHS to capture (or copy off a firestore), MPEGStreamclip it to 1080p24 HDV, make a proper sequence in FCP and go. Timing seems to stay correct, and there’s no duplicate frames.
    I’ve posted a screengrab of the sequence settings and a bit more info on my blog:
    http://www.discretecosine.com
    Videoboy70 replied 20 years ago 2 Members · 1 Reply
  • Videoboy70
    August 29, 2006 at 5:26 am
    i didnt find the info on your website and I really need it. Can you help?
