Activity › Forums › Adobe After Effects Expressions › Cut & Paste slider expressions to new layers updating name links?
  • Cut & Paste slider expressions to new layers updating name links?
    Posted by James Ronan on January 19, 2016 at 8:50 am
    Is it possible to cut an effect and it’s expressions, and paste them on to a new layer (maybe in a new comp) and automatically update the expression links / name etc to the new layer?
    If not built in, is there any handy scripts anyone is aware of that could look in it?
    I’ve done a bit of research but not found anything yet.
    James
    Kalleheikki Kannisto replied 10 years, 8 months ago 2 Members · 1 Reply
  • Kalleheikki Kannisto
    January 20, 2016 at 6:44 pm
    In the same comp, I don’t see a need for any change in the expressions.
    If your expressions are linked into some other property in the same layer, they will “retain” the relative links when copied to a new layer, i.e. will pick the values from the new layer they’ve been copied to.
    Similarly, if your expressions are linked into a property in another layer, the expression is already linked to the right layer without any need for changing the values.
    Linking to another comp is a different story.
