Activity Forums Apple Final Cut Pro Legacy Cut on the Bleeding Edge…. “Tape Trouble”
  • Cut on the Bleeding Edge…. “Tape Trouble”
    Posted by David Rowan on June 9, 2005 at 11:55 pm
    I’m trying to get our brand new system to work.
    Dual 2.7 G5 running OS 10.4.1. Just installed FC-Studio. Downloaded the new drivers from AJA for my IO and installed them.
    Everything seems to be communicting well, but….
    When I try to capture from tape about half the time the capture will quit with a warning message that reads:
    “Tape Trouble. Check VTR. Do not attempt to eject tape or use transport without checking VTR first”
    The tape deck is fine. The message comes up a few seconds into the capture. Got the same problem with “Capture Now”, “Capture Clip” and “Batch Capture”.
    So any ideas? Is there something I can do to make the whole process less sensitive to any tape jitters?
    DWR
    Jim Martin replied 20 years, 4 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    June 10, 2005 at 4:30 pm
    Clean the deck… I only see this when it’s got dirt on the heads…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Jim Martin
    April 14, 2006 at 10:11 pm
    did you ever figure out what the issue was, David? I’m currently getting the same error messages.
