Activity Forums Apple Final Cut Pro Legacy Cut list handle in Cinema Tool
  • Cut list handle in Cinema Tool
    Posted by Alexandre Chartrand on October 14, 2008 at 9:08 pm
    Hi
    I’m an experimented FCP editor. I’m working on FCS1 with Cinema Tool to manage a DI workflow. I’ve got a feature that I’m trying to send to the neg cutter. He’s requesting that I give him 32 frames handles on the cut list. But Cinema Tool only allows up to 5 1/2 frames on each cut. How do I get handles up to 32 ? I’m looking for the easiest solution !
    Alex
    Alexandre Chartrand replied 17 years, 11 months ago 2 Members · 2 Replies
  • Steven Gonzales
    October 15, 2008 at 11:21 am
    You might try using transition handles. Set that to 32, then see if you get handles on each cut point.
    If not, maybe throw a 1 frame transition on each cut, then use transition handles set to 32 to force that extra 32 frames.
    You can put transitions on every cut by setting your default transition length, then selecting all in the timeline, then drag that selected timeline clip bunch over to the “overwrite with transition” overlay in the canvas.
    Of course, you should do all this experimenting in a copy of the sequence.
  • Alexandre Chartrand
    October 15, 2008 at 2:25 pm
    Thanks Steven !
    I’ll try this once I know everything else doesn’t work… it’s an hour and fourty minutes film… I’m afraid I’ll have to recheck every transition to make sure they’re OK….
    But thanks for the idea, it might be my way out !
    Alex
