Activity Forums Adobe Premiere Pro Cut clips the same way like in Sony Vegas
  • Cut clips the same way like in Sony Vegas
    Posted by Gennady Gaidukevich on October 19, 2018 at 4:55 am
    Is it possible to make some kind of hot key that would cut the clip in the place where timeline pointer is at the moment? Will try to explain you what I mean. I know there is Cut tool that you can use when press С but problem with it is that after I press C I need to aim with mouse pointer before I cut something and sometimes things get inaccurate. Is it possible to cut the video like in Sony Vegas where you press S and it splits the clip where your timeline pointer is. I hope you got me. Thanks in advance
    Tero Ahlfors replied 7 years, 10 months ago 2 Members · 1 Reply
  • Tero Ahlfors
    October 19, 2018 at 6:24 am
    Yes. Sequence – Add edit or Add edit to all tracks.
