Activity Forums Adobe After Effects Customize layer sources for escential graphics creations?
  • Customize layer sources for escential graphics creations?
    Posted by Jeshua Reyes on August 15, 2018 at 7:25 am
    I was wandering if there’s any way to, as the text sourse of a text layer, you chan choose wich clip you want a given layer to display and make it customizable in the escential grapichs panel to the use it into Premiere Pro; like making full custom transitions or animations.
    Emil Stefanow replied 8 years, 1 month ago 2 Members · 1 Reply
  • Emil Stefanow
    August 23, 2018 at 1:27 pm
    Let’s say you have a comp with following 3 layers:
    1. Text
    2. videocomp_A
    3. videocomp_B
    You want that when people type in “A” in the essential graphics text field, then Videocomp A is visible, when people type in “B”, then Videocomp B, or?
    Put the following code in the Opacity of videocomp_A:
    myTextLayerContent=thisComp.layer("Text").text.sourceText.value;
    if (myTextLayerContent == "A") 100 else 0
    and for videocomp_B:
    if (myTextLayerContent == "B") 100 else 0
    Best regards
    Emil
