Activity Forums Apple Final Cut Pro Legacy Custom setting in Compressor
  • Custom setting in Compressor
    Posted by Matthew Cohn on December 17, 2010 at 8:06 pm
    I’m trying to create a custom setting with pass-through audio in Compressor. I create the setting and set audio to “pass-through” and save it. Then I drag it up onto a job in the Job Action Window. But when I click on the setting once it is applied to the job in that window, the audio setting in the inspector window changes back to “Enabled”. When I click on the icon for the setting I saved with audio as “pass-through” in the settings window, though, the audio is still set to “pass-through”. Is the audio setting for the applied setting still “pass-through” even though it changes to “Enabled” in the Inspector window when I click on it the Job Action window? Is there something else I have to do to ensure that the audio is set to “pass-through” when I submit the job?
    Thank you,
    Matt
    Matthew Cohn replied 15 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
