Activity Forums Adobe After Effects Expressions custom particle orient toward center of the comp
  • custom particle orient toward center of the comp
    Posted by Sarah Schela on May 10, 2012 at 3:43 pm
    Hello there,
    I am looking for a way to orient the custom particle generated with particular towards the center of the 3D comp. (I wanna try a kind of ring where all elements face the center point).
    I’m using an expression for “rotate y”.
    I tried to use the expression “lookAt” (lookAt(position,thisComp.layer(“Null Camera 6”))-> Null Camera 6 is the center position), but unfortunately it doesn’t work.
    It must be possible somehow! Any help appreciated.
    Sarah Schela replied 14 years, 4 months ago 1 Member · 1 Reply
  • Sarah Schela
    May 10, 2012 at 3:53 pm
    lookAt(position,thisComp.layer(“Null Camera 6”).position)[1]
    works better. but just on “two sides” of the circle.
