Activity Forums Adobe After Effects Custom noise field
  • Custom noise field
    Posted by Paul Rijkaard on March 25, 2016 at 7:43 am
    I’m working on an animation which uses a field of noise or visual static as the main element – specifically in afx I have been using cell pattern.
    A sample animatic is here
    https://vimeo.com/160303905/6c836be72e
    i would like to customise the noise so that it is less regular and more truly random.
    Eg according to the image below the cell pattern in afx relates to pattern d, a so called quasi-random distribution, whereas I would like to create a distrubution closer to pattern a.
    https://imagebank.osa.org/getImage.xqy?img=OG0kcC5sYXJnZSxvZS0yMC05LTk2OTItZzAwMQ
    Does anyone know of a plugin which might help to achieve this or if you could point me in the direction of an expression type which might help.
    Many thanks
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Kevin Camp replied 10 years, 6 months ago 3 Members · 2 Replies
