Activity Forums Apple Final Cut Pro Custom LUTs
  • Custom LUTs
    Posted by Odille Grouillard on November 30, 2019 at 10:27 pm
    Hello,
    I have a custom LUT from a shoot. Imported it, applied, and it looked great. For one of the cuts, I removed the LUT and exported it raw. Now I need to reapply the LUT and that doesn’t seem to be an option. The clips with the working LUT two additional options in the Info Inspector:
    1. Color Space Override (off is selected)
    2. Camera LUT (custom LUT option selected)
    The clips without the working LUT don’t have this option.
    Any help would be great.
    O
    Odille Grouillard replied 6 years, 8 months ago 2 Members · 3 Replies
  • Odille Grouillard
    December 1, 2019 at 9:04 pm
    Sorry for replying to my own thing, but I think I might not have been clear:
    I simply want certain clips to regain the following options in Info Inspector:
    Right now, they’re simply not there.
    Is there something obvious I’m missing? I just can’t find the solution.
    Any help would be great!
    Odi
  • Brad Hurley
    December 2, 2019 at 2:24 pm
    I’m not sure how to re-enable that in the inspector, but there’s another way to add a custom LUT, which is to go to the effects browser > color > Custom LUT, and drag that onto the clip(s).
    One big advantage of this approach is that you can position the LUT after an initial color correction; you can even do this with camera LUTs. I rarely use LUTs, even technical/camera LUTs, but when I do I insert them this way.
  • Odille Grouillard
    December 8, 2019 at 10:51 pm
    That totally worked!
    Thank you so much, Bruce!
