Activity Forums AJA Video Systems Custom LUTs won’t load in Kona 3 (but do on Kona 2 system)
  • Custom LUTs won’t load in Kona 3 (but do on Kona 2 system)
    Posted by Grant Lovering on July 2, 2008 at 9:38 am
    We are trying to load a custom LUT into our Kona 3 system. Enabled custom LUTs, select from the predefined list and no problems. Select choose file to load in a LUT from a file and it reports the following error.
    “File not found. LUT values are unchanged.”
    As a test have tried loading the same LUT into one of our Kona 2 systems and works fine so the format of the LUT seems to be correct for Kona (have also opened in a text editor and looks correct to the Kona specs in the manual).
    We then uninstalled Kona drivers and reinstalled the current drivers still no joy.
    Have logged a phone support call with Kona, still waiting.
    Can anyone confirm if the ability to load a custom LUT is working on Kona 3 with the 5.1 NDD drivers (have also tried with just 5.1) or if you have any clues on solving this one….greatly appreciated!
    Cheers.
    Grant Lovering replied 18 years, 2 months ago 2 Members · 7 Replies
  • 7 Replies
  • Gary Adcock
    July 2, 2008 at 11:49 am
    I am checking on this,
    It is my understanding that both versions of the driver use only the standard 1D LUT file.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
  • Gary Adcock
    July 2, 2008 at 5:17 pm
    [Grant Lovering] “Have logged a phone support call with Kona, still waiting. “
    They are on it..
    gary adcock
    Studio37
  • Grant Lovering
    July 2, 2008 at 9:38 pm
    Thanks Gary for your help on this one. That is my understanding too. We have used cineSpace to generate a Kona compliant 1D LUT and have confirmed that it loads fine in Kona 2, but Kona 3 will not load it, reports a file not found error.
    I had a cineSpace tech check the LUT file too and confirmed it looked technically correct.
  • Gary Adcock
    July 2, 2008 at 10:00 pm
    Hey Grant
    the good news is that AJA has just posted an update for the Control panel for those working with LUT’s under leopard ( 10.5.x)
    From the AJA website
    AJA Control Panel application for LUT support under OS X 10.5.x
    (Release Date 7/2/2008, ZIP archive)
    This alternate version of the AJA Control Panel application addresses an issue where the Custom LUT window will not allow the user to load a LUT. This version of the AJA Control Panel application is only necessary for users working with LUTs and the KONA 3 under the Leopard OS. After downloading and unzipping the application, simply drag and drop it into the Applications folder on the boot drive, and when prompted, replace the older version of the application with this version.
    https://www.aja.com/ajashare/AJA_ControlPanel_7-2-08_app.zip
    gary adcock
    Studio37
  • Grant Lovering
    July 3, 2008 at 10:42 am
    All fixed….thanks for your help Gary.
  • Gary Adcock
    July 3, 2008 at 11:56 am
    [Grant Lovering] “All fixed….thanks for your help Gary.”
    your welcome, but thanks really go to the AJA for posting a quick fix.
    gary adcock
    Studio37
  • Grant Lovering
    July 3, 2008 at 12:24 pm
    Hey Gary,
    I’ve just posted a new thing to solve re: 10bitRGB and 10bitRGB LOG, wondering if you know on this one?
    https://forums.creativecow.net/readpost/98/870596
    Cheers,
    G.
