Activity Forums Adobe After Effects Custom layer shape properties transfer to mask
  • Custom layer shape properties transfer to mask
    Posted by Ed Romero on April 28, 2012 at 11:50 pm
    How can I add the shape properties to a mask on a solid? I’d like an identical shape as a mask instead of a shape layer.
    Best way to do this?
    Thanks.
    Ed Romero replied 14 years, 4 months ago 2 Members · 3 Replies
  • John Cuevas
    April 29, 2012 at 3:39 am
    Select the shape layer, then on the menu bar Layer -> Auto-trace.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • John Cuevas
    April 29, 2012 at 4:24 am
    Also, if you just need your shape layer to be a mask, you could just put it above the layer you want to mask and change the bottom layers track matte to alpha matte.
    Thinkck.com
  • Ed Romero
    April 29, 2012 at 10:20 pm
    Thank you!
    I had tried a track matte but it wasn’t working.
    When you suggested track matte, I tried again and found I couldn’t see the contents inside the shape layer because the gradient fill was low. Raised gradient fill to 100% and it worked great. 🙂
    Auto trace is also a good solution. Of course there is much more control with the shape layer and track matte.
